Originally posted by: Arkaign
Anyhow, most of those things contain PTFE. PTFE is a double-edged sword. In a really rough, gunked-up motor, it might help by smoothing the internal surfaces a bit, but it's also known to actually build up as well, forming a layer inside your motor that might inhibit somewhat the flow of oil.
I've heard good things about Marvel Mystery Oil.
Originally posted by: Zenmervolt
PTFE will never attach itself to engine surfaces and will provide no additional lubricative benefits. In order to get PTFE to attach ("plate") a surface, a technique is used that employs high heat (over 900 degrees) in a complete vacuum. Neither of those conditions exist in an automotive engine. Most of the PTFE particles are simply filtered out by the oil filter, clogging it faster and reducing its ability to clean the oil.
Do not ever put any PTFE additive in an engine. Never.
ZV
My general advice = flush your oil, use a quality synthetic, and change regularly. If you've been using regular oil for a long time, a few changes of synthetic and you'll reduce a lot of the gunk and carbon deposits in your motor. This is even more true with the paraffin oils (Royal Purple, AMSoil, etc).
Now, the last time I got my oil changed, they recommended I get a tranny flush
Question: If I drive a 2003 Dodge Neon, is there any advantage to putting in Mobile 1? I actually take my car to the dealer to get my oil changed. They send me coupons a few weeks before it's due for the 3 month checkup, which makes it several dollars cheaper than other places. Anyways, they offer the 'regular' oil and then the Mobile 1 Synthetic. Are you saying it may be best to mix up the oil I put in every now and then? Regular this time and Mobile 1 the next? Is one better than the other for Winter/Summer months? Mind you, it gets 100F+ in the summers and hits -40F and colder in our winters.
On a side note, I kinda skipped my 30,000 mile maintenance! It may or may not be the smartest move, but I just rolled over 42,200 last night and was thinking I'd get some preventative maintenance done. Now, the last time I got my oil changed, they recommended I get a tranny flush and several other things done. Is this worth it? Anything I can check myself? Engine seems to be working fine and has never given me any problems.
For this kind of work, I've been told to stay away from the dealers. A few car buddies of mine bring their autos to only one shop in town whom they trust the most. Any benefit to going to one place or the other?
Sorry for jacking the thread!
~Travis
I've never had the timing belt/water pump worked on that I know of. Perhaps it's in the list of parts to work on for my 30 or 45K maintenance checkups? My friends only tell me they trust one shop in town, so I'd probably go with their recommendations, as long as the shop uses OEM parts. (I believe they do, but I'll double check) I have never manually done anything with the radiator, but I know they check all the fluids at the dealer where I get my car's oil changed.
My biggest grip with the Neon is the infamous squeaky brakes.
~Travis
