I have an Enermax EG365P-VE 350w power supply that has served me faithfully for a few years now, but has suddenly decided to go on strike and totally refuses to function. I have a simple ATX power supply tester and when I turn on the Enermax all the voltage status LEDs show up as green (which is good) but then turn off half a second later (which is bad). The +12V led will stay lit for a few seconds afterwards but then will fade out to nothing.
I checked the internal fuse and it's fine. The fans give one brief twitch when the power supply is turned on, but that's all. It's not the end of the world if I have to pitch it, but I would rather salvage it if possible.
Any tips/links/suggestions would be appreciated.
