Enermax MultiFunction Panel Problems
cornelp
83
I have one of these Enermax Front Multi Function Panels.
Enermax UC-9FATR2S
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=144398
I have installed it and it was all good. The USB works, the firewire, all good.
After a few days, I see in my computer that the Card Reader did not show up. I tested the USB and firewire and SATA ports on the unit, and works fine, no problems, but the Card Reader will not show up. I rebooted, and still no show.
I opened the case, removed the USB Cable connection that goes to the Card Reader, and connected to the USB port next to it. I wanted to use a different port, maybe the one used before did not work anymore.
Well, when I rebooted, the system came up and the Card Reader showed up. Happy. Now a few days later, again the card reader will not show up again. I put it back to the previous USB header, and again the same thing happens.
It seems that the card reader will not show up all the time.
I have an Epox system that has the same problems. It seems that the Card Readers always gives me problems.
Anyone had this problems before? Anyone know what i can do about it?
Just looking for a solution to this beside opening the computer up everytime the reader will not show up.
Thank You All...
