enermax.. enough power?
adams828
I'm looking at the Enermax CS-3051L-S3A case, which comes with a powerup "350w" power supply. Now I'm sure that although it's called a 350watt PSU, it probably has a lower output. So I'm curious, if I'm building a p4 2.6c/abit ic7 rig, probably with 1 cdrw drive and either 2-3 HDs, but with no immediate plans to overclock, will this PSU be adequate for now? I do like the way the case looks.. and the $56 price tag is quite attractive. My plan would be to use this setup for now, then upgrade just the PSU once I decide to start overclocking. Is this a good plan, or do I have to suck it up and buy a better unit now.. and if so, any suggestions? Thanks!
i remember reading somewhere that the powersupplies in their cases are similiar and built like enermax PS's
if you want to be sure that it is enough, calculate alol the wattage that you need from all your parts then add 20-30%, if its still enough, then you are good.
well it's not so much that i don't think it's enough power.. just concerned with the quality of the psu, ya know? sometimes generic is fine and sometimes it's not 😛
ENERAMAX cases dont always come with ENERAMAX power supplies so it might not be too good >_< antec on the other hand always comes with antec power supplies so that's why their cases are usually worth the extra $$$
