Ok guys, I've been out of the loop for a while, but I'm no newbie so bear with me.
I just rebuilt my system from scratch, and used my old Enermax 431W power supply. Here are the system specs:
P4 2.0A
Asus P4PE
512MB Corsair XMS 3500 DDR (1 stick)
Gainward GF4 Ti4200 128MB
Adaptec 2940U2W
WD 100GB Special Edition (8MB cache) x2
Plextor UltraPlex 40max
Plextor PlexWriter 12/10/32S
Plextor PlexWriter 48/24/48
Pioneer 10x SCSI DVD
Floppy
Drive bay card reader
2x 80mm fans and 1x 92mm fan (all Sunon) in back
3x 80mm fans on radiator (stock Koolance)
All this is packed into a Koolance full tower with the 200W gold block on the CPU and a block on the video card too.
Running the system at all default values / voltages under XP Pro doesn't produce any problems- but the 12V+ line runs at about 11.8V under full load. At 2.5G the 12V line drops to 11.6V (idle) and 11.2V (full load). The core never goes over 40 degrees C. All values are pulled from the latest version of Sandra.
The system runs mostly stable under Prime95 and 3DMark 2001 looping continuously- no crashes, but Prime95 sometimes errors out, sometimes after 18 hours, sometimes after 30+ hours. Any attempts at higher speeds, no matter what voltage- they all produce errors under Prime95. Worst case- I tried running the chip at 2.8G @ 1.85V, and the 12V line dropped down to 10.8V. Running the chip at higher voltages at only 2.5G results in lower 12V+ measurements and decreased stability. All motherboard and RAM settings were kept at stock values.
Other power rails- the 12V- dips to -11.2 at worst, while the 5V+ never goes below 4.9V, and the other rails all stay within a few tenths.
Now I've searched through as much of the forum as I could, and it seems like many of you are running more taxing setups than mine on this power supply without any problems. I'm trying to break 3.0G on this CPU, but I can't get past 2.5G no matter what voltage I try or no matter how cold the CPU runs. It just seems like I can sprint straight up to 2.5G but hit a brick wall immediately afterwards.
I assume this means I need a new power supply- but I want to get all of your input before I drop another $120 on something bigger/better. Could I have 'worn out' the 12V rail on my previous system? I've had this PSU for over 2 years, and it's been through quite a few ridiculous setups.
Thanks for reading, and thanks in advance for any input.
P4 2.0A
Asus P4PE
Adaptec 2940U2W
Floppy
