Enermax 350 HELP!!!!!!!!!!
Guardian
54
I have an E350 and my system won't boot. The power supply won't even start since the fans don't start spinning. I've been using the E350 for about a month. Please tell me it's not dead cause it's not exactly the cheapet. My system still works with my 200W power supply.
Russ
Guardian,
Make sure the external power switch isn't flipped to the off position. If you've only had it a month, you're still under warranty, so no need to worry about the cost.
Russ, NCNE
damien6
1,256
I got mine from Russ and it's great. He even personally emailed me when it was shipped, which in itself is a great feat since he's here ALL the time. ;)
