Hi,
Just built a new machine. Installed XP first and spent the time updating it, drivers etc. before installing vista 64 on a separate hard drive. Went thru the vista setup & chose the two separate OS path, etc.
After getting vista all setup, I went back into bios (I guess this is the only way) and changed my HDD boot order to the XP drive. Restarted and I get a "boot mgr" error when booting from XP drive (partition) now. Not sure what the problem is. I did change my drive/partition volume names under vista. COuld this cause the problem in XP?
Also, isn't there an easier way to create a dual boot than having to go into bios everytime?
Thanks for any input
