Enabling 64Bit on a Crippled A64
imported_Skorpio
I recently just found out that my Compaq laptop which was advertised as a Athlon XP-M was actually an Athlon 64 but with 64bit disabled.
Story here:
click
Is there any hacks or any way to enable the 64bit capability?
I'd guess you would have to have a look at the chip and see if there are any obvious mods to it. IIRC the mobile A64's did not have heat spreaders so this might be easier then with a desktop chip... anyway look for the old bridge cut and post some pics.
Any reason you need 64 bit instructions on your lappy? don't tell me you wanna put 8 gigs o ram in there 🙂.
no not for 8 gigs...just so my laptop wont be obsolete so quick. lol
Is there any software mods or hacks? I heard its probably disabled through their custom bios.
Nope, it's turned off on the CPU and can't be enabled. There's no exposed bridges or pin mods that could help.
EDIT: You could always throw a Mobile Athlon 64 in there.
