- Oct 9, 1999
- 1,571
- 1
- 76
I was reading on the AVS forum today, where they were trying to get rid of noise in the ground plane and EMI inside a PC case. Aside from routing all the power & data cables and stuff, I heard something new. Apparently the component leads that stick out the back of the mobo make decent antennaes and radiate directly toward the mobo tray, causing a good deal of noise. A solution is to clip off all the stubs, leaving only the rounded solder joint. Has anyone tried this? Can you get higher FSB or RAM overclocks?
