- Jul 30, 2000
- 1,829
- 0
- 0
Hi
My friend was running a Dell PC with win 95 on C. We installed a maxtor 20GB hd and ran the maxblast software and formatted adn made 4 equal size partitions on the new one, as well as 'imaging' the original drive to one new partition on the new HD).
We screw3d up the install big time and it was trying to boot off the new one (it needed to be cable select)-- it wasn't until several hours later that we found out that it was booting the first partition on the new hard drive (that had the image on it) as C and then the old C as D --- and finally we got the drive and partitions recognized in the right order. But in the meantime, we messed up win95 on C. In the command prompt, we can see the drives, sizes adn theotectically the data.
So, after talking to MS for about 2 hours, they said we have to unistall internet explorer before we can reinstall win95 over itself. MS suggested not installing Win98 over win95, at this point.
So here are my questions:
1) On the MS site, we have found two articles, Q175610 and Q174549, relating to uninstalling IE4, but I think she has IE5. Will the the article still apply? Couldn't find anything about IE5 there.
2) Assuming we get win95 reinstalled, I suppose it won't see the new HD bc the partitions are too big? What do we do? Do we have to repartition? Is there some way to salvage the data on that maxtor? (She has no CD burner or zip or anything like that).
3) Anything else we need to know? We will be reattacking the situation Mon eve EST.
4) I have no way to tell what version of win95 is on that install CD.
5) In the worst case scenario, can I just plug that maxtor into my win98SE PC and still boot from my C and span CDs with that image?
--Does win98 have a size restriction on partitions adn will we have boot problems (I have installed CD burners into mine as slaves-
--does that mean that if I put the maxtor in it would also be a slave or mightbe be cable select)?
Thanks everyone.
Thanks everyone.
