EMERGENCY QUestion: will this ADAPTEC SCSI RAID card fit in my Lian Li PC 60XX case??
i am getting this card: Adaptec AAC-364 with 128MB cache
for my SCSI raid setup.
Dimensions:
Full-size PCI card (12.283 x 4.2 inches; 31.191 x 10.668 cm)
WILL that card fit into my lian li PC 6085 case or ANY PC60XX CASE? Help plz
another card linky SPECS
Anyone? help me plz..thanks
Is your case small like this?
If so, then it will not fit with the HDC installed.
What mainboard are you using?
This is an Ultra2 interface. (80MB/S MAX per CH)
You will be severely bottlenecked with 15.3's at the rate of more than one disk/CH.
Are you looking for high STR or I/O? Adaptec cards (even the new ones) are rather poor in the former area.
-DAK-
hi shuttle.
yes that is my case ,same dimension.. i am planning to get 2 Cheetah 15.3 Ks for RAID 0 on that card. Good idea?
As long as they are on separate channels, you should be OK.
What mainboard?
32/33 PCI will limit you to about 110 MB/S...
-DAK-
hi there, thanks for the reply. Yeah i am using 32 Bit PCI 🙁 if i wanna do RAID with that card, is it a good choice thou? the on board cache makes it appealing. I am using it for video and heavy graphics editing. So what is ur take?
mainboard is probly a Canterwood Board
