Y yankeesfan Diamond Member Aug 6, 2004 5,922 1 71 Nov 5, 2009 #1 I need to cut my nails, but I can't find my nail clippers. CAN IT BE DONE?
YOyoYOhowsDAjello Moderator<br>A/V & Home Theater<br>Elite member Aug 6, 2001 31,205 45 91 Nov 5, 2009 #2 I use my swiss army knife scissors
MartyMcFly3 Lifer Jan 18, 2003 11,436 29 91 www.youtube.com Nov 5, 2009 #4 Scissors, Knife, or a blowtorch. Use your discretion.
xanis Lifer Sep 11, 2005 17,571 8 0 Nov 5, 2009 #7 Are you serious? Go to CVS or the grocery store and get a new pair. Problem solved.
GodlessAstronomer Lifer Oct 27, 2007 17,009 5 0 Nov 5, 2009 #9 Rub them on the pavement until they wear down.
FoBoT No Lifer Apr 30, 2001 63,084 15 81 fobot.com Nov 5, 2009 #10 Cheeseplug said: You gots teefus, don't you? Click to expand... when i was a small child, like 3-4 years old, i would bite my toenails
PhoKingGuy Diamond Member Nov 15, 2007 4,685 0 76 Nov 5, 2009 #11 I know how to do it perfectly but im not going to tell you because you're a yankees fan
