EMERGENCY, need to find a power supply for a Gateway
Polishwonder74
474
Ok fellas, save my life. I just had a power supply on a Gateway fry itself and I need a new one QUICKLY. I guess all the gateway stores closed about 3 or 4 months ago, so that's no help. This power supply looks like it's a real custom job, with a real goofy fan built-in. Do you guys know where I might be able to dig up one of these really fast? The computer is a Gateway Essential 933C, and here's the documentation on that power supply: http://support.gateway.com/s//...500545/6500545nv.shtml
Thanks in advance, fellas.
mechBgon
Oct 31, 1999
30,699
If Gateway's pinout info for the PSU is accurate, then it appears to not be a standard ATX pinout on the 20-pin power cable. I compared their diagram to an official ATX specsheet. They don't match up, unless Gateway has goofed their diagram up. You could do a reality check on that using a live Gateway, a live standard ATX system, and a voltmeter.
If the affected computer simply has some data that you need, then here are a couple of other ideas:
1) take the hard drive out of the Gateway, put it in a working computer and recover the data to the working computer
2) get out an idle computer, put the Gatway's hard drive into it, and do a Repair-install of Windows. To do this, start Windows Setup from CD, and the first time it asks if you want to Repair or do a fresh install, choose a fresh install. It will get ready, show you the EULA, then look at your hard drives and you should have it install to the existing C: partition. It will notice the existing Windows installation and ask if you want it repaired, and now you say Repair oh yes pleeeze pleeeze repair it :( and just let it go through the motions of installation. It should come to the surface with the programs and data intact.
Good luck :)
PS: method #2 will leave you with a "raw" Windows installation that needs patching, so run it by Windows Update at the earliest opportunity.
lost0822
63
i had a gateway till about a month ago...i got it back in Nov. of last year and had to replace the power supply. I bought a standard ATX antec true power 420, fit perfectly and worked without any flaws.
Polishwonder74
474
Ok, I tried a normal ATX power supply from another computer and she fired up. Also, I stopped by CompUSA and physically matched up the PS from the gateway with one of their store brand PS's. It appears that it's actually a standard micro ATX supply. I'll run it with the big PS and the cover off and order an Antec from Newegg. Thanks for your quick responses, guys. I really appreciate your help.
Zepper
18,998
It's a little late but I was going to say that the dimensions look like a standard SFX (microATX) PSU and the ATX power connector pinout is also standard except the Gateway lacks the -5V line - which is going bye-bye anyway as nothing uses it any more. Ain't it swell of GW to give you a whole 90 Watts... :roll:
. I would suggest a Fortron replacement as they are excellent - you should be able to get twice the power for only $20. or so. at newegg.
.bh.
:moon:
