Email on VPS using CentOS 5.4 only works if sent and received within same domain?!?
Check your /var/log/mail.{log,warn,err} to figure out what's going on. How is mail setup on the box? Are you using an external relay server or a local SMTP server?
this is probably caused by the fact that i changed what port emails are used on the master.cf in postfix folder, it reads as follows:
# service type private unpriv chroot wakeup maxproc command + args
# (yes) (yes) (yes) (never) (100)
#smtp inet n - n - - smtpd -o content_filter=spamassassin
587 inet n - n - - smtpd
i commented out the first line because i wanted to use port 587 instead because verizon blocks port 25 and i need this email to work in outlook. when i did this email started working but only locally. not sure what to do
if i put the file back to its original, email starts working again like normal, but only in webmail
ok so this works:
but i have no idea why?
submission inet n - n - - smtpd
-o smtpd_sasl_auth_enable=yes
-o smtpd_client_restrictions=permit_sasl_authenticated,reject
