Hello,
For a couple of months now, hardware problems have been popping up on my m6809.
They are:
-LCD screen flickers or turns black. Seems to be a connection problem because if I adjust the screen, the screen goes back to normal. I haven't gotten the cracked hinges fixed yet, though.
-USB ports on the left side don't work properly. My Wacom Graphire3 jitters when I plug it in on those ports. Also, my iPod mini will not charge on the ports. I can revive the iPod somewhat so I can access the iPod's drive, but the battery will not charge at all. (I feared that the iPod has a dead battery)
-The USB ports on the backside turn off suddenly. It's very frustrating when I work with my Wacom and/or a USB mouse then suddenly the ports stop working. A restart fixes this, but it is very annoying. Problem happens even when I have the power settings to "Always On". I have the power setting to "Portable/Laptop" right now but I didn't set any of the ports to "Allow computer to turn off this device...".
-The DC connector seems to be loose. Plugging in the DC cord needs jiggling/tugging to get the connected LED and the yellow charging light to go on. <-This might be my fault because the cords get tugged on when I place my laptop on my lap.
Also, did anyone else update their BIOS to the BIOS given by eMachines through BigFix?
I would like to know if there are known problems with it and if it is still possible to flash back to the original m6809 BIOS because I don't have the original.
ANY help will be greatly appreciated. I bought the machine in a Portland, OR Best Buy and bought the extended warranty. I've spoken to a Coquitlam, BC, Canada Best Buy and I was told that they don't honour the U.S. extended warranty. This is really odd/unfair since the warranty pamphlet clearly says "International coverage". I will try again at a recently opened Best Buy in Vancouver, BC. Also, I will be going to the U.S. next week and I might bring along my m6809.
Sorry for the long post, but I tried to be as clear as possible.
Thanks a lot.
They are:
Thanks a lot.
