FROM ELSAs WEBSITE
ELSA 3D REVELATOR, Generic driver for TNT/TNT2, GeForce and GeForce 2 GTS .
Driver with OpenGL (NVIDIA TNT/TNT2-M64/TNT2) and D3D windowed support for ELSA 3D REVELATOR
info: This driver is developed especially for graphics boards of other manufacturers. For ELSA graphics boards please use the corresponding ELSA driver.
Get the diver here.
DRIVER
MORE HELP:
If you get an error message ("Unable to find driver entry in drivers.ini"
😉 when trying to install the Revelator driver, you will have to extract the rvl_w9x.exe in Windows Explorer and change the graphics adapter in the 'Display Properties'. To do this, do the following:
Locate the rvl_w9x.exe file in the directory you saved it in.(You did download it, didnt you?)
Right hand mouse click it and choose Extract to folder "drive:\ foldername\"RVL_W9X
Then go to the desk top, right click and open Display Properties.
Go to 'Settings', 'Advanced Settings', 'Adapter'.
Click change and the 'Update Device Wizard' begins.
Choose 'Display a list', then 'Next'.
Click 'Have Disk' and browse to locate 'ELSArevl.inf' in "drive:\folder name\"RVL_W9X
Click OK and select the shown driver
Finish the wizard and restart.
The ELSA 3D REVELATOR driver should now be installed OK. You should now be ready to use the ELSA Revelator Glasses on your graphics card.
