Elsa Gladiac + MSI KT7 Pro2-A problem
Xylor
12
I just built a new machine for the new year consisting of the following:
MSI KT7 Pro2-A
T-bird 1GHz (not overclocked yet)
2x Crucial 128MB CAS2
Elsa Gladiac
SB Live
Adaptec 2940UW
Quantum 15GB Fireball LM
Quantum Viking 2GB UW
Quantum Atlas 1GB (narrow)
3Com 3C905C-TXM
300W Antec Power Supply
Dual booting Win98 (not SE) and Win2k Pro
The problem I'm having only seems to occur under Win98 when running games in either D3D or OpenGL. Every few minutes or so I get a single frame flash of color. It appears that this frame is random, it does not occur at fixed intervals. The AGP aperature side appears to affect the frequency that this screen flash occurs, it's worst at 64MB aperature setting, less frequent at 128MB setting. Setting the aperature size to 256MB causes instability problems so is unusable. I have tried all 4-in-1 driver combinations from 4.25 to 4.28 with the same results. I have also tried multiple versions of NVidia's reference driver as well as the drivers available on Elsa's site. Video driver versions tried range from 5.30 to 6.49. I'm convinced it is some sort of an AGP related problem probably caused by texture swapping, but I've tried everything I can think of. It occured to me that this problem may be resolved by re-installing WinME on my machine, but I don't like the fluff that MS has decided we all need in WinME so don't want to do so unless it's my only option.
Any suggestions?
Bomberman
Maybe you have already done this ... have you tried setting the AGP speed to 2x? Via chipsets usually don't work like they are supposed to @ AGP4x (I often had crashes with Via chipsets/AGP4x, maybe you just get artifact ... ). Setting the speed to AGP2x solved all of this for me :) .
Xylor
12
Bump...any other ideas? I know the difference between AGP 2x and 4x is negligible, but I hate to think the only solution is to nerf my performance.
Mem
21,476
13
Xylor,try tweaking your BIOS from
Orangedelta ,4x AGP should work fine, I`m running my Geforce2 MX card & MSI K7T Pro board at 4x AGP with no problems in any games.Btw try installing latest monitor drivers as well.
