Elsa Geforce 2 GTS problem? please help.
ninja
33
Hi everybody,
I need your suggestion to correct my video card problem.
I puchased this card on Jan and replaced the TNT2 Ultra (Diamond). It worked fine and I have not noticed until recently. When I play the 3D simlation game (WWII, CFS II, B-17), part of the screen is flashing or flickering here or there. I reintalled all games but it doesn't help, so I emailed Techsupport of Elsa and tried some trouble shoot, but it didn't help either. So, finally I put back the TNT2 Ultra, it works perfectly.
Athlon 1GHz
Windows 98 SE (DirentX 8.0)
384 MB RAM
350 W PSU
KT7-RAID (WW)
Elsa Geforce 2 GTS 32 MB DDR (Nvidia Reference Driver 12.41)
Voodoo II 8 MB
Holleywood Plus DVD decorder
Sound Blaster Live
US Robotics 33.6Kbps Internal Modem
Kenwood 52X
Pioneer 32X
Teac 12x10x32
Pioneer 16x DVD
Maxtor 4 IDE drives :(
Theslowone
1,779
Might get a better response in video, but i will give you my two cents.
The flickering can be caused by many things, one is the io voltage. In your bios(most of them) you can change the io voltage from default(3.3 normally) to 3.4 or 3.5, adjust the io in the smallest increments but dont go to high. I would stop at 3.5. If the card is not oced then it might be something weird such as a small ps, that is a pure guess. but i can link you to a site that list a lot of stuff it could be. It is a hercules site but all in all should be the same answers.
This is the link to the site go down to past the drivers.
Hope this helps
