Ello would like some help with K8Ngm2-fid
DCDenton
Ello. I Just recently put together my system mostly for lans(hence the microatx setup) From watching the forums here and with lil banging my head against keyboard i noticed that i cant change the vcore. Does this mean i cant achieve higher then 2.3ghz stable OC? /pout.
I havnt tried much of messing with the ram cause when i try(im prolly doing something wrong) it wont post/boot so i have to reset bios. I dont want to do something too stupid.
Some help would be great thanks
Althon 64 3200+ 10x 230.
Geforce 6800 GS ( Preoverclocked nothing of my doing yet)
1 Gig (2x512ddr pc3200) 2.5-3-3-8
You are probably overclocking your ram too much. You need to set the ram divider to 166. This divides the HTT clock down to 208 Mhz @250 HTT for the ram. I just installed this motherboard and am running it at 10x250 with Crucial Ballistix memory running @ 208 Mhz 2-2-2-7 1T. The max HTT clock on this motherboard is 250. I haven't figured out how to get the CPU fan to throttle down during CoolnQuiet operation even though the processor is running at 1Ghz and 1.1 volts.
Merv
Eh thanks for the advice, i tried that but didnt work, unless the limiter in the bios isnt what you mean by dividing it.
