Recently, found a hot discussed ATX case. Some guys said it is perfect and very easy to use, others said it is normal. The Link shows it is a totaly screwless ATX Case with 1 mm steel plate but I am still not cery clear. I got some questions.
1. Is there any problem to run PIII 1000 and voodoo 5500 ?
2. Is it really easy to access, I mean i need to exchange my hard disks frequently for my multi-Operation system. Is the rails reliable?
3. Do I have to remove the power supply to install/uninsatll the CPU?
4. Is the Case solid ?
I am going to build a brand new system next week, eveything is ready except a ATX Case and a CD-RW. Your guys's any help will be appreciated.
Here is the Link
Here is the Link
