Here's a basic question for you guys who are into electronics -
I have a motor that I need to turn 180 degrees, to move a valve from open to closed and vice versa. However, I would also like to have *adjustment* capability, so that I could stop the valve at any point in between 0 and 180 degrees.
Ideally, I would have a simple dial type switch, so that as I turned the dial back and forth, the motor would emulate the switch position. Does that make sense? So every time I moved the dial, the valve would move in exactly the same way.
What I'm wondering is how involved something like that would be, and what exactly would be needed? Would I use a stepper motor and some custom controller, or ???
