Electronic Toothbrush? User's opinion need!
gredodenda
359
I just bought a Sonicare electronic toothbrush at Costco.
Acoording to the manual, Gel toothbrush works best. Anyone using Gel toothbrush? then Which one is the best??
Can Sonicare electronic toothbrush really make my teeth Whiter?
Thanks all,
even though I bought it, i'm still curious how it works.....
diskop
1,262
I don't have that particular one, but the electric toothbrushes that I've had over the years tend to break down and stop working quicker than I would like it.
Mutilator
3,513
10
I'm using colgate total gel with my sonicare... havn't used paste. Had the thing for a month or 2 now. I'd have to say my teeth are a little whiter than when I started... it definatly cleans them a lot better than a regular brush.
B00ne
2,168
I guess u mean electric toothbrushes (unless u use ground old microchips for brushing that might be referred to as electronic :) - they are awesome. I miss mine ( my luggage got stolen 2 weeks ago = teh suck) my teeth dont feel as clean anymore since I had to go back to the conventional muscle operated ones...
hoihtah
5,183
get sonicare
they rock.
i have baun... pretty good. but for the same money... i'd definately get the other one.
JamesM3M5
218
Sonicare toothbrushes rock. I dunno how exactly how they work, but I'll try to explain. Something inside the handle vibrates at 30,000 Hz. There are magnets on the brush head assembly that pick up the vibration and in turn vibrate the head of the brush side-to-side at 30kHz.
The whole brush handle is sealed water-tight. They charge by picking up the current from the base. There are no metal contacts to charge or to vibrate the bruch head. It's pretty damn cool!
Nightfall
1,769
Another vote here for the Sonicare toothbrush. :)
I love mine and I will never give it up.
I don't use a Gel toothpaste. In fact, I use Crest Tartar Control paste and it works great. :)
geoff2k
1,929
Do they break down pretty regularly? What can I expect my yearly toothbursh budget to become if I start using one of these?
B00ne
2,168
Originally posted by: hoihtah
get sonicare
they rock.
I had the Braun too, I just checked, those sonicare are insane they cost like 3 times as much as the braun ($150)
Mutilator
3,513
10
That $150 Canadian? I got my sonicare quadpacer for $89 from Walmart. They had the personal model for $79.
B00ne
2,168
that is euro (dunno how to make the sign) but since EUR=$ i thaught it doesnt matter ( price was found in germany and compared to what i payed for my braun)
Pooteh
503
brauns are now 24.99 with different colors. just go to frys
actually its 6 times as much now:)
Imported
14,679
23
My mom got 3 Sonicares for $90 at a dental convention. They're great. :D
Previously, my dad paid $90 for just one..
glen
15,995
30,000 hz is certainly faster than other brushes, but heck does that really make it better?
Is there a type of magical plaque that doesn't come off till you hit 30,000 hz?
HiveMaster
Banned
Apr 11, 2002
490
My wife buys those 6 dollar throw away brushes. She loves them.
Uh...
Oh you mean for brushing teeth????
Sorry can't help you there....
Mutilator
3,513
10
Hive you gave me an idea...
They need to make a Sonicarpetcare.
The worlds most powerful steam cleaner. It'll clean the dye right out of your carpet fabric! ;)
JeremyJoe
660
I use whatever tooth paste when i used that but the dentist said "good you are getting the areas that most rearly brush" but now i just have an old fashion tooth brush and i dont feel the cleanness i ones did :(
Thegonagle
9,773
I'm new to electric toothbrushes, so I bought cheap. First, a Colgate Acti-Brush. It's OK, but I'm currently using a disposable $5 Crest Spin Brush that's styled like a race car. I like it.
incallisto
1,473
Thanks all,
I use the Sonicare with Tom's of Maine. Toothpaste. Works very well, and no harsh chemicals. :)
walrus
1,544
13
I got a Sonicare over in Hot Deals free, a long time ago, just used it this morning. You're going to love it . I only brush with Tom's Wintermint tooth paste, with what ever brush I use.
Peetoeng
1,866
I haven't changed my sonicare's brush in 1.5 years. I always dip it in peroxide after use, tho. How often do u change your brush?
