Hi,
I want to start a small personal project for my house, and at a point i'll need to create a LAN switch with specific size and form.
So before going around searching for something that probably doesn't exist (it's really a specific size and form), I want to create one for my needs.
For that, I need the electronic part of the circuitry for the LAN switch.
Since I'm a software developer and not an expert in electronics, can anyone help me finding a proper schema for a LAN switch?
What I need:
- One RJ45 entry connector (that comes from another switch) it would be a cross-link, to avoid auto-cross feature. I know I'll only connect there from another switch, so it may be always-crossed.
- Two RJ45 connectors. I may connect 2 network adapters there, or even use them to connect to another 2 switches (one for each) on the crossed connector explained in the above point.
Thanks
What I need:
Thanks
