electromagnet question for the tech gurus
MrDudeMan
15,069
94
i would post this in high tech but it would get locked...
and this is the only other place where lots of people frequent the forums and there are some smart cookies...
so here it goes
i am making a project that involves some really strong e-mag's
it is a chair or sorts that levitates and can hold up a person
it needs to be able to support between 150 and 300 pounds (easily) and maybe 350-400 absolute tops, but more the middle range
anyways, it is a fairly easy project and if you are interested, PM me and ill send you pics and such as they turn up, but what i need to know is what kind of magnets to get to make this possible
i found this site that has TONS of e-mags that require hardly any power, but it seems WAY too good to be true
here is a good site i found with some magnets (the ones you are pointed to are round...if you click on the left menu you can get to other types of e-mag's and if you go all the way back to other magnets, but im not really interested in those)
according to this chart i should be able to get the ER(1-3)-503 series which can hold 600+ pounds at just under 50w of power and the net weight is 13lbs
that seems like way too much lifting power for only 50w of power...someone help me out here!
dighn
22,820
4
dunno too much about these industrial things but theoretically given any power you can have as much lifting power as you want because the lifiting power is a function of the magnetic field which is a function of the current not the power
i dont know if your levitation idea would work though, what is your idea of goinga bout it anyway?
MrDudeMan
15,069
94
im fairly sure it will work. i have been discussing it for quite some time now with my physics teacher (he is a pretty smart dude. dunno all of this qualifications
and what not, but i know he is really smart). anyways, it involves a seat with one of these magnets on the inside with north pointing toward the floor. it then
has little rollers/magnets lining the inside lip which will hang down over the bottom part of the chair. the bottom part will have another of these huge
magnets with north pointing up to repel the seat. the sides of the seat part will be flanged in a way that it wont slide off from side to side and probably have
some sort of track so it wont fly up either. it will have power cords on the inside on a track, not wires, so they dont tangle no matter how many times you
spin around.
sorry, i know this isnt very clear, but its rather hard to explain w/o a chalkboard
edit: i know how magnets work and i know fields are generated with current, but current is part of power, and the power has a lot to do with it depending on the voltage applied.
dighn
22,820
4
spin around.
oh i see so there is something to mae it stable. sure that wouldnt be a problem
i thought u wanted to go for a pure leviation with no physical support which would complicated to do
MrDudeMan
15,069
94
spin around.
hehe yeah that would be awesome though :)
what do you think about those e-mags in that link though? seems like i was able to find them way too easily and they are perfect...hmm
dighn
22,820
4
true current is part of power but it's inverse to voltage for a fixed wattage. now those magnets run on 12/24 dc, for 50 watts that's ~ 2-5 amps of current which is a lot of current
if they say it works... i dunno it should work? LOL. 2-5 amps is a lot, i'm more towards believing it can hold that much weight
edit:
the * beside the weight say * Holding values stated are under ideal conditions rated at 50% of the actual value.
wth is that supposed to mean
MrDudeMan
15,069
94
yeah i mean 5 amps is a sh!tload of power for a magnet but STILL i mean 600#? wow if this works...
Gillbot
28,830
17
to hold up that much weight it will need a bit of power. The problem you may run into is if you build it to hold 300lbs, and a lighter person sits in it, it may not be as stable and vice versa.
MrDudeMan
15,069
94
well we are going to use stabilizers
around the ouside lip of the seat there will be magnets with north pointing inside and around the base there will be more small magnets with north pointing outside, so the seat will be repelled upward and outward, causing it to stay in the center (mostly) and then we are going to (somehow, not sure yet) attach the seat so it cant fly off upward when it is powered up and there is no load besides the net weight of the seat.
MrDudeMan
15,069
94
if someone lighter sits, it just wont sink as much. i am going to design it for roughly 250# (or around my weight). i think the max it will be able to hold is WAY more than that, but we shall see.
compudog
5,782
If you are using DC magnets in the lower voltage range you should be able to build a power supply to vary the current for different loads. This is the easiest type of power supply to put together. Perhaps a modified DC motor drive could be adapted to power the magnets, because a DC motor is just a magnet of sorts.
MrDudeMan
15,069
94
i thought about doing this but how hard would it be to guage how much it could hold at given current? i could always use a computer PSU because that would be perfect...12v and it can go up to 15A usually...so one could power both, or to be safe i could use 2 computer PSU's...
hmm
compudog
5,782
There is no way to vary the current output of a computer PSU without modification. There are a couple ways you can vary the current with a DC drive though, as for how much a given output can support, you would need to develop a scale by trial and error. Say you had a total load of 5 amps DC at 24 volts, you could set the control pot to full and it would support the max of 500 pounds. Then you could set the control pot to 50% and it would have an output of 2.5A and support, say 150 pounds. I don't think it would be a truly linear or easily computable curve. Anyway, once you do your trial and error, you could label the know, at it's various positions, for the weight that would be supported. As for determining the amps, you could use a digital multi meter or a dedicated ampmeter. Most of the stuff could be found online or at an industrial supply house.
MrDudeMan
15,069
94
by using a computer power supply...i meant use the 12v line and put a POT on it...that will definitely limit the current on it. i know it will because i have done it. but i see what you mean about the rest of it and it makes good sense. i appreciate your ideas and will probably utilize your trial and error technique in my project.
