StageLeft
I am aiming to rig up some LEDs on an RC plane and as such have to get back to understanding the basics of electricity. Imagine, I'm not even being paid or made to do this!
I do not understand current/voltage properly. I know that:
Power(P) = Voltage(V) * Current(I)
and
I = V/Resistance(R) <- Ohm's law
So, a 60 Watt lightbulb running at 120 Volts is also going at .5 Amps (60=120*.5).
First question: What dictates a lightbulb's wattage? A house lightbulb has a fixed 120 Volts, and since its power (watts) are based on the volts and current, a lightbulb must be setting its own current levels so that when the fixed 120 V is put through it, its power of 60 W is figured. Now, Ohm's law says that if we know its Voltage (120) and its current (.5), V/I = R and its resistance would be 240 Ohms. If this is the case, the only difference between a 60W and 120W lightbulb would be that when the 120 W bulb was built, it was designed with a lower resistance (120 ohms) through choosing its wire materials/thickness of wires, etc., right? Does this new 120 W lightbulb have a 120 Ohm resistance only at 120 W or is that a hard set-in-stone resistance? I presume the latter, since radioshack sells resistors that have ohm ratings and do not seem to say what voltage those ohms are at.
Second question: Is a lightbulb or an LED or anything else of similar simpleness pre-set in its current and always will "ask" out of an electric circuit for that amount of current? In other words, the 60W bulb will always be asking for .5Amps and the 120W will always ask for 1 A so that if I took a 60W bulb and shot 240 volts through it, it would now have 120 watts going through it? OR, is it always pre-set in its resistance, so a 60W bulb knows it's 60W because its maker knew it would have 120 V and gave it an appropriate resistance to create the right current that would make 60 W? In this way, a 60 W lightbulb at 120 V would end up being 240 W at 240 volts because a doubling in volts also doubles its current, so now instead of .5A and 120 V for 60 W, it's 1 A (240 V/240 Ohms) and 240 V, so 240 W.
Third question: In the case of an LED like this (ledshoppe<- replace stars with the word 'ledshoppe') would I treat its internal resistance as effectively 0 and that's how I would change its current (since it talks on there about the thing's continuous and max current)? So, if I hooked a 4 V battery directly up to the LED it may immediately with its low resistance, ask for a ton of power and burn itself up right away, which would mean that for me to get the correct resistance and play with those current figures, I could get the power I want?
Fourth Question: Can resistors be run in series? I presume so; 120 ohm + 120 ohm = 240 ohm
Fifth Question: Can LEDs take unlimited voltage? I know they won't run below their forward voltage, but if I have a typical LED and run a million volts through it, will it work as long as I have a miniscule current (so, vast amounts of resistance) so that the power is still in the range it likes?
Thanks! I knew this was the place to come to. I can only hope I'm not actually as stupid as I appear and that perhaps in the past I understood this inately, but I won't rely on that hope 🙂
and
