Electricity Help!!
StankCheeze
36
Anyone know a lot about electricity and formula related stuff? I am stuck on a stupid ass online homework question that is stupid and easy and when i put the right answer in it says no. i have 1 guess left until i am penalized...so ...help heres the question with a formula! you just plug in the numbers...but..its stupid!!!
Resistance =
resistivity of material * length of wire / cross sectional area of wire
resistance is in ohms
1 inch = 2.54 cm
100 cm = 1 meter
You wish to make 13 ohm electric heating coil from 18 gauge nichrome wire. The resitivity of nichrome is 1E-4 ohm-cm and the cross-sectional area of 18 gauge wire is 0.001276 in^2.
What length of wire in meters is needed? _________ meters
fill in the meters part please!!!!
RossGr
3,383
That is the correct answer for cm,10.7m though. if you do not understand where it came from the whole point of the problem is missed.
First of all this is a pretty simple algebra problem and if you are haveing trouble with that aspect of your course you may want to consider finding a math tutorial.
Let R = Resistance
RV = Resistivtity
CA = Cross Sectional area
L = Length
The first step in this problem is to convert the Area to cm^2, get everything in the same units.
You are given
R = L*RV/A
solve for L
L = R*A/RV
plug in your numbers.
You always want to check the dimemsions of your result
R = ohms
A = cm^2
Rv= ohms*cm
so R*A/RV = ohms*cm^2/ohm*cm = cm
so the result is in cm, surely you can do the conversion to m?
Wizkid
2,728
StankCheeze: maybe your error was converting square inches to square centimetres, 1 inch = 2.54 cm, but 1 inch squares = 2.54^2 cm^2... so 1 inch^2 = 6.45 cm^2...?
Passions
6,855
Everyone has trouble with algebra time to time, here is a detailed explanation:
The Length of wire is described by L=R*A/Rv
A= 0.001276 x 6.4516/1= 0.008232 cm^2
Therefore,
R= 13 Ohms
A= 0.008232 cm^2
Rv= 1x10^-4 Ohm-cm
L comes out to be 1070.19 cm. Convert to m, that brings you to 10.7019m.
TBP
919
I wonder why we need in. when the rest of the world are using cm.
Bleep
Hey I was not happy when they went from Cycles to Hertz or from MicroMicro farads to Picofarads
Bleep
