Electricity experts weigh in - using an extension cord for an appliance (kegerator)
seepy83
2,132
I recently purchased a kegerator that is U.L. approved for outdoor use. The owner's manual has warnings that say it should not be connected with an extension cord.
It has GFCi built-in to its plug. It's a standard 3-prong plug, and the specs for the appliance say 115 volt, 60 cycle, 15 amps. edit: manufacturer lists 1.7 amps.
What is the risk of using a heavy duty outdoor extension cord to power it? It wouldn't be a very long distance...either a 15 or 25 foot cord.
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
Extension cords are not designed for permanent installation. They are for temporary power only. The warning on not using an extension cord is not for decoration.
highland145
43,973
6,338
The longer the run the more the resistance which could cut the life of the compressor. I can see some guy with a 100' cord running this thing. 15 amps.
When's the ATOT party?
CPA
30,322
4
how about just install a new socket, running off the one you were going to plug the extension cord into, assuming your amperage is high enough on your breaker.
seepy83
2,132
I'm going to run a new outlet to the other side of my patio where it will be placed, but that won't happen for 3-4 weeks. In the meantime I was going to connect with a 12- or 10-gauge outdoor extension cord to get it running for the holiday this weekend.
It sounds like a short run like this shouldn't be that big of a deal, especially since it's temporary.
sdifox
100,859
18,078
3 weeks is ok. Just use the shortest extension with the thickest conductor.
TonyG
2,021
Just for this upcoming weekend? You should not have any issues, and the 12guage cord should be more then capable of handling 12 amps at that distance.
IndyColtsFan
33,655
688
This. If you're going to have a kegerator outside, just have an electrician install the proper outdoor socket and you'll be good to go.
EDIT: Just saw that it was just for this weekend -- you're fine with an extension cord for something small like that. Just make sure it is out of the way and be careful about running it into a doorway where a door may pinch it and break the insulation.
JimW1949
244
Use a 12 gauge heavy duty outdoor extension cord. Buy an extension cord that is as short as possible. If it is possible to keep the extension cord from getting wet where the kegerator plugs into the extension cord, that would be a good idea too.
highland145
43,973
6,338
The problem isn't the life of the compressor but the extension cord heating up and catching on fire.
Here OP, 12 gauge extension cord:
http://www.amazon.com/2883-Heavy-Dut...ref=pd_cp_hi_2
Both.
Voltage drop on wires due to resistance causes hotter wires and less voltage to run the devices attached to it. You may have noticed the same effects of voltage drop when using an electric drill that is attached to a long extension cord. The drill still runs, but is often slower, with less torque, and tends to heat up more quickly. Voltage drop has a devastating effect on motors.
edro
24,326
68
A beefy extension cord would work fine. Of course they don't want you running it from an extension cord because of all of the code and liability issues.
- Using too small gauge cord = fire/death
- Too long of a cord = voltage drop = poor performance = warranty claims
- Damage to cord due to misapplication (using indoor cord outdoors)
- Numerous NEC Code violations
- etc.
Use a beefy cord. 12ga recommended, 14ga is good enough. You will be fine.
seepy83
2,132
So what is it about an extension cord that makes it drop voltage over distance, where Romex wouldn't? Is it because extension cords use a stranded copper conductor and romex is solid?
sdifox
100,859
18,078
too many interfaces.
Golgatha
12,424
1,110
Normal 20A indoor outlets are wired with 12ga solid core. Use a 12ga extension core and you'll be fine. Just be sure to get the shortest one needed for the application. Typical 12ga cords are rated for 15A, so don't plug anything besides the kegerator into it. Get a 10ga with 20A service for some headroom if you like. It will be hard to find though and much more expensive.
SphinxnihpS
8,368
25
So my whole house is wired with only 14GA wiring, can I safely use the Kegerator?
A regular indoor/ourdoor extension cord will be fine. Just don't coil up the excess and put it under a rug. If the device has a GFCI breaker on it, you don't even have to worry about it getting wet.
