- Jun 19, 2000
- 18,883
- 641
- 126
Selling my home. Buyer had an inspection done. Inspector is saying that grounding was done incorrectly in a sub panel in the attached garage that is fed from the main panel. Buyer wants it corrected by a licensed electrician. But I am not certain that the inspector is correct in his assessment.
The sub panel is being fed by three wires. My quick research shows that a bonded bus for the grounds is required in a sub panel fed by four wires. In a three wire sub panel, the neutrals and the grounds can be attached to the same floating bus which is how it has been done. I'm not an electrician but it seems to me that in a panel fed by three wires, if the grounds are on a bonded bus, they will have no path to ground and that they must be attached to the same floating bus as the neutrals. Yes, how I am relating this is, I'm sure not how an electrician would say it but I am hoping that I have explained it clearly.
Regardless of whether this was done correctly or not, I must have an electrician out. I guess I'm wondering whether a pissing match will result if the work has in fact been done correctly. What electrician is going to take the time to put something in writing that refutes what a licensed inspector working for a national inspection company has cited? Should I have this looked at through a GC? I have a friend who is one. I'm thinking he might be in a better position to argue this case should it need to be. Things are picking up here and the trades are starting to get busier than they have been for a long time. The electrician that did the work many years ago is making noises like he's way too busy to come out to even look at this but I have not given up on him yet.
I also need some GFCI work done and there is some moisture damage in the roof sheathing in the garage from a leak around a can vent that needs to be corrected.
Out of the laundry list of sometimes picky shit the inspector came up with I feel that the buyer is making reasonable requests and ignoring the crap. This is a good thing.
