Electrician-type Advice Needed...HELP
crt1530
OK. I have a 300 foot long driveway. At the end of the driveway we have lights. Somewhere along the driveway, the power line going out to the lights is broken. I need some kind of tool to find where the break is in the line(the line is 18" down). I'm pretty sure there is such a device, but am unaware what they are called or where to find them. What I will most likely end up doing is get a ditch digging machine and lay a whole new line. Please help me think through this.
Thanks.
You don't need a megger.
A megger is used to test insulation breakdown. It is a meter that puts out around 1,000 volts and checks to see if you have any ground leaks. I use 'em all the time on industrial drive motors. They will shock the piss out of someone if you clip the leads on them when they are not looking, and they light up flourescent lights pretty well.
There are buried line tracers you can buy/rent, but the cheapest way and probably the best way to go is to dig the line up and replace it. It broke once, and they usually break again and again due to moisture getting in the cable/age/etc.
(Edit)
I'm sure you've done this already, but make sure the cable really is broke, and not the lights or something. Turn off the power, try to get both ends of the buried cable (Before it goes into the lights), connect the hot and neutral together, and check the other end with a voltmeter. If you get a few ohms, its good, and the lights are at fault. Connect the hot to the ground wire and check if you have a reading. If you do, the neutral is bad, and you can hook up the neutral on the lights to the ground as a fix.
If you really want to fix it right, dig her up. Run all new direct bury Romex. I also recommend you have a certified electrician inspect your work before you bury it. Sometimes they give good hints/pointers, and save your ass from your insurance company in case you screw up and burn your house down.
if its broken you can buy an EF (elecrical Field - known as a magnetic field) meter around..
Its a pen that has a light on top, when taken near a high power source (above 12 volts) it lights up saying there is power.
If ther is a leak it will find it since it would be radiating outside the line..
Just go to Home Depot and ask someone there.
Thats not going to work The_good_guy. For one, they only have a range of a few inches. I have a Fluke one, and it goes up to around 4" if you are lucky, with nothing in the way. He is 18"+ inches underground. Second, if the neutral is broke, then it will show the whole line being hot, and you will never find the break.
Yep, bury a new cable (if it's bad). Make *sure* you do not nick the insulation, and do not lay it against any sharp rocks in the trench.
You might want to replace the setup with a low voltage line, then you won't have bury it so deep, but 300 ft. thats a long run.
