Electrical problem or is my headlight out?
Status
Not open for further replies.
Savij
4,233
The driver's side headlight is no longer working but the highbeams and corner lights are all still ok. Normally I would just change the bulbs and be done with it, but I noticed that was out once before but when I went to the autoparts store the light was working again. That doesn't sound like the bulb being burned out. Normally I would just buy new bulbs and see if that fixes it but replacing headlights requires removing the bumper on this car so I don't want to go through that in subfreezing weather if I don't have to.
I'm thinking this may be related to the driver's side fender being replaced since the first time I noticed the problem was immediately after I picked up the car. I'll probably take my car back to the body shop, but I wanted to get some opinions here in the meanwhile.
'04 Acura RSX.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
High-beam is a separate filament, so it's perfectly possible for the low-beam to be burnt out while the high-beam is still OK, even if it's the same bulb.
Chances are that it's the bulb, but if you can get to the connector with a multi-meter that will tell you for certain.
ZV
Status
