electrical problem: electric stove on 30 amp breaker
roid450
858
we have an electrical stove that is hooked up to a 30 amp breaker (that's what it is supposed to use), the stove being the only thing on that circuit. when all 4 heaters on stove are turned on, and oven turned on, the breaker trips after only a 3-4 minutes. the stove is brand new.
any ideas why the breaker is tripping :Q :confused:
Loreena
297
Most electric ranges require a 50A circuit not a 30A. With a 30A you will not be able to run the oven and two cooktop burners.
blahblah99
2,689
Post the power requirements of your stove.
My guess is 240V 50A required.
roid450
858
sorry it took so long. this is at my parents other place. i will find out tomorrow for sure though. thanks for the help.
xgsound
1,374
8
Electric stoves with an oven generally require a 50A circuit. That includes thicker wire between the breaker and stove to prevent an electrical fire. Perhaps the old wiring was for a cooktop unit or separate oven.
Double check the AMPs required for the stove. If the stove only requires 30A, it may only be a loose connection at the pigtail bad breaker. If 50A is required you will need at least 8 AWG wire (this is expensive, but costs less than a fire) if the run from breaker to socket is not excessively long.
See this thread for why 8 AWG wire is needed for a 30+A circuit. http://www.handymanwire.com/ub...87&page=0&fpart=1&vc=1
Jim
