- Aug 10, 2002
- 5,847
- 154
- 106
What do you do when your neutral bus in an electrical panel cannot physically accommodate a wire?
Inspection revealed my electrical panels are not bonded to any earth ground. I figured I can just run a #4 stranded copper wire to the incoming water pipe and drive some grounding rods into the soil outside my house. Connect all the wire segments together with split bolt connectors and finally connect the panel's neutral bus to this wire to complete the job. (main panel, not a subpanel)
Only issue is that I cannot fit the #4 wire into the holes in the bus. So I have a few options:
1. Unstrand the wire at the last inch and push half of the wires into one hole and half the wires into the other. Something about this feels like a shortcut and possibly not to code.
2. Can I screw a lug into one of the holes on the bus and wire the #4 to the lug?
3. Replacing the bus with one that can accommodate a #4 wire is the least desirable option but I will do it if there is no other satisfactory/safe/code meeting option.
