Electrical: light switch getting hot
JTsyo
12,068
1,159
I have a slider switch that's going to the chandelier. If the lights are on for awhile it switch gets really hot. Is this OK or could the switch be seeing more load that it should? Are there special switches for chandeliers?
PottedMeat
12,363
475
if that's a standard incandescent dimmer, it uses a triac which will get warm.
last time i checked those dimmers were good for ~500W. add up the bulb wattages and see what you get.
dud
7,635
73
How old is the unit?
If the switch is getting too warm consider replacement.
0roo0roo
64,795
84
Different dimmers have different wattage ratings...I think the higher wattage ones pretty much have a big heatsink.
You might upgrade or try using cfl to lower load
herm0016
8,524
1,132
cfl usually does not do well with dimming, some are designed for it but the life is still much shorter.
Analog
12,755
How many watts are you putting through it? If its old, I would just replace it - its not worth the chance of a fire.
Eos
3,463
17
Our west facing wall has an outlet and even with no devices plugged into it, it gets warm in the evenings...
SparkyJJO
13,357
7
Do not do this. They are not able to be dimmed by conventional methods.
sdifox
101,209
18,222
that's because your wife uses the plugged in dildo all the time while you were out.
