Puffnstuff
I've got a grounding issue ever since I moved my stuff into a new case and I'm puzzled by it. I've checked and double checked for anything that might be grounding inside yet I find nothing. While I was trouble shooting it I did notice that when I changed the power cables supplying the gpu that the noise changed a bit. Hell I even swapped out my enermax galaxy 850 ps for a corsair hx1000 just to rule out the ps. Could it be possible that the interference that I'm seeing could be caused by my graphics card if it were going bad? I even tried using a ground lift adaptor on my pc just to rule out fan and power cables inside the case even though I visually inspected them yet the problem persists. At this point I'm open to suggestions as I've pretty much exhausted everything I know to do to solve this little mystery.
