dullard
I have a sensor (thermocouple) within an aluminum case that has some other electrical components (mostly resistive heaters and a DC power supply). Every few months, I can see a large amplitude 60 Hz noise on the thermocouple voltage. The noise lasts for a few hours and then it just instantly goes away.
I would like to reduce that noise as much as possible. But I know nothing about it.
1) Do you know of a good intro to topics like this? I would like to educate myself and answer questions such as these:
2) I assume since there is a 60 Hz noise, that it is related to the 60 Hz AC that we use. Is that a reasonable assumption?
3) Does the aluminum case (1/16" thickness) shield the inside from outside noise?
4) Would an AC filter like this have a chance of helping? Or should I try to further shield the thermocouple?
