Hey All,
I probably should have restructured the below link a little bit and posted it here instead of Off-Topic, but I didn't really have the questions until I had a little time to reflect. I was just happy as Crap that nothing important was lost, and was more focused then on sharing with others then figuring out what questions I still had.
Anyway. The LOOOOONG Post from me is below, and I have electrical Questions following for you circuit gurus: You'll have to read the post to be able to relate to my questions.
Surges Fried
1. My Office, and Kitchen were on two separate breakers, but the wire was actually looped from the Kitchen Circuit to my office circuit. So, when we cooked, and had my computers running, the kitchen circuit would trip, and the office circuit would be out (but not tripped). Is this a logical behavior, or should that have told me something was amiss as well? Both circuits are 15 AMPS on the breaker, and the stove is not included in the above mentioned circuit.
2. Are there any tools you can use to detect what happened to me preventatively, or is that something that has to happen before it can be fixed or detected?
3. Any difference electronically between a Surge Protector with AVR , or the surge protector section of a UPS with AVR (Automatic Voltage Regulation)? AVR is key to preventing system damage, correct? Would you assume that the UPSes would have fried just the same as the surge protectors had they been plugged directly into the socket?
4. Electricity runs from the + to -. If the circuit is broken then electricity won't flow. How does a neutral fit in? If you're answering this you've probably forgotten more about electricity then I'll ever know (hey I passed Phys 300 (Electricity and Circuits) a loooong time ago).
When the neutral jumped, what was it that really happened?
Thanks,
Chris
Surges Fried
Thanks,
Chris
