THESANTINI
So, I have not invested in a UPS, which I will. Regardless, my surge protector seems to have failed me during a quick power on, power off, power on, power off storm. All this happened in < 10 seconds time.
The storm passes, I check to see waht the damage is to my computer. Bios comes cleanly. It begins loading Windows, and it runs blank / black screen. So I go to startup options for Windows, try running in "Safe Mode;" no dice. Then, "Last known good boot configuration;" no dice.
I try reinstall Windows onto this same hard drive, it freezes at 2% of Windows XP installing the installation files, after running a quick format. No dice.
Fine, I dust off the same brand HDD which was last running as part of a RAID configuration. Same deal, NFTS format, then freezes after 2% onf installation files are installed. No dice.
The Windows XP cd was used no more than four weeks ago to format my said machine and run a fresh install of XP.
What are my options? I think its possible to be my hdd (but it formats fine) or my dvd-rom drive causing these problems.
