DeathFlame
A couple questions, for any of you that have this pump.
Noise level? (used inline...)
How do you connect the 3/8" tubing to this 1/2" diamter output (I believe that is what is is)?
And I might not be able to find room in my case, would it be possible to mount this at the rear of my case (outside, and how would I connect it...)
Oh, and I guess one other thing, what are the dimensions (maybe it will fit in here)
