Originally posted by: JaredExtreme
This is definitely tempting. That cooler looks LOUD though. Would have to replace it with one of those NV5 Silencers.
Yeah, how loud is this card?
Originally posted by: THUGSROOK
yes, and if its anything like the 5900s ~ it works very very well.Originally posted by: Killrose
core OCing really shouldnt be an issue ~ due to throttling.
So there is some sort of overheat protection in nVidia's bios/software that throttles the core?
advise for running 6800 cards~
use a 500+W psu
raise vagp to 1.65v (motherboard vagp)
these cards use alot of power ~ and i mean ALOT OF POWER! :Q
not enough juice could fry them...... easily 😉
we already know how to get around the throttling.
(my 5900 is throttle free, same can be done for the 6800s)
Originally posted by: Rollo
So even though you've probably OCd about .0000000000000000000000000000000000001% of all chips that have been OCd, I can't consider your statement as having any merit.
(no offense intended, just pointing out your experience is "sand on the beach" and not generalizable)
BTW, will the NV5 Artic Silencer even work on this since the 6800LE has the PCB layout of the 6800 Ultra which blocks the second PCI slot that the NV5 uses as an exhaust?
Right, that might be true (though I have owned basically every mid/high end card released throughout the past year or two) but unless there was something already somewhat defective it's hard to believe that the card died from overclocking (assuming just normal methods were used). I'd even bet that it probably was something else in his pc (if in fact he didnt mess with it otherwise).
I had problems due to a psu, which was 430w and modded with better lines across the board, power is a very big issue with these cards and I didn't even believe the reports of that until I saw it myself.
Electromigration happens as a result of increased voltages on a smaller process (my understanding) and when you increase the voltage on the smaller process part which was not designed to receive that much voltage, heat in the smallest parts of the chip goes up and you can have electrons 'migrate' to where they aren't supposed to be which results in internal failures inside the chip. This was a big issue with the northwood originally came out IIRC, and we had to stay under 1.70v to avoid 'SNDS' (sudden northwood death syndrome) which is in fact very real-- and no matter what cooling was used you had to basically stick to that for long term use. Some people with vapochills had P4s die with higher voltage, so it's not so much a tempreature thing as a voltage thing which is my basis for saying I don't think he killed it by moving a slider.
Not postiive, of course; but I think he might have received a defective card to begin with. If this drops below $300 I may pick one up to play with.
Originally posted by: PremiumG
just to cool you guys down:
this card takes up two slots and might NOT have 16 pipes opened.
Can't a real 6800GT be had for $350 or so if you shop around? Why not pay the extra $25 for a single slot, guaranteed 16 piped card?
Pfft.
1. The "real" 6800GT has 10% slower RAM
2. The "real" 6800GT has a cheaper cooling solution
3. Since when have gamers cared about the slot next to their AGP card?
4. Last I looked, one brand of 6800GT was $350 at one place, and that brand has a cheesy new cooling solution nobody seems to like. 6800GTs are $375 > at newegg I believe.
This card is the deal of the century. Although you are right that it may not have all 16 pipes, that would make it equivalent to the Asus V9999GE which splits the difference between a 6800NU and a GT, and with 10% faster RAM, this card would be even closer. Besides, has anyone actually gotten one that is 12 pipes?
Hmmm. I always thought electromigration happened because the increased heat somehow facilitated the current arcing from circuit to cicuit and ended up fusing the two. It's been a long time since I've read about it though, maybe someone else can save us a Google?
Originally posted by: virtualgames0
This card is noisy as hell! Is there any thermal throttling for this? It seems like it's running at max speed 24/7 unlike my former 5900.
Also I think the thermal sensor is broken, it's stuck at 98°C
I felt the heatsink with my hand, it didn't feel like I could boil water on there, or even fry eggs, it was just lukewarm.
