Bug list updated:
http://forum.efi-x.com/viewtop...=16&t=234&p=1097#p1097
Should I buy an EFI-X today?
Well, as of today...
1. Sleep does not work and resets your BIOS to "safe" settings
2. Time Machine does not work on non-primary drives (pointless if it's on the same partition as your boot drive)
3. AFP/Bonjour do not work for Networking
My big gripe is lack of Time Machine. Sleep isn't a dealbreaker and you can use a 3rd-party $8 Encore card to fix AFP/Bonjour, but running without backup is just crazy. imo what happened is simple:
1. They came up with a great product and set a release date
2. They overshot their release date but thanks to media/consumer pressure they released it early, not wanting to relegate it to vaporware status
3. They did so, figuring they could release firmware updates in the future that would fix the early problems
As much as I want to complain about this, all companies do this. I've worked for companies that do this. It's ridiculous, but it's just how the system works. Fortuantely EFI-X doesn't require a hardware upgrade, just a simple firmware upgrade which can be done easily anytime.
So should you buy an EFI-X chip now or not? Well...they have a lot of orders, so there's a few-week waiting period right now. The EFI-X guys said there is a major firmware update scheduled for release in October. My guess is, based on my above idea of the events that occurred, this will fix all of the issues that the first-gen release has. So it
may be a good time to purchase an EFI-X chip because chances are you won't get your chip until after the 1.1.3 update is released, which should (hopefully) fix the majority of the bugs, especially the main ones.
The core product is solid - it does what it advertises, i.e. lets you install a retail Leopard DVD to your compatible PC. However, it has some bugs in the details like Time Machine and Sleep. However, those just need a firmware patch to fix. I think their programmers just needed more time to release the 1.1.3 firmware to get those details ironed out.
So I have mixed advice...on one hand, as of today, the details work pretty crappy. You can't backup your machine, you can't put your machine to sleep, etc. OTOH, the product is good and just needs some additional programmer, the first wave of which is coming out next month. Soooo...it's up to you. I can't make a good recommendation right now. If you're a tinkerer like me you may enjoy it, but in it's preset state I can't recommend it as a solid piece of hardware...but the next firmware update could (and probably will) change all of that completely. So I guess, stay tuned!
