Has anyone come across the above situation, i.e. a fibre link under 300M using single mode fibre, but terminated on media converters or SFPs for multi mode fibre.
I'm not suggesting fitting this. I would just like to know what effects the above is likely to have. I have seen this at a customer site. The fibre run is less than 300M, but its been done with single mode fibre. The media converters are an old no name brand, and its not clear if they are for single or multi mode fibre.
After checking I noticed some SFPs for the Cisco SMB switches are show as compatible with both single and multi mode fibre. Is there likely to be any problem using them with a fibre run of 200 to 300 metres, or would they need an attenuator as for single mode fibre its a very short run.
Thanks in advance.
Rob.
Thanks in advance.
Rob.
