Effects of Memory Speed on CPU Overclocking
Jephph
333
I know that memory speed typically doesn't make huge performance difference by itself, but how much higher a CPU overclock can you get with say, a DDR2 1333 set compared to a DDR2 800 set?
Gillbot
28,830
17
If you are fsb limited in your overclock, stepping up to a faster set of ram can lift that restriction. My old OCZ PC2-6400 (800fsb ram) limited my OC to 400fsb, with my new Buffalo Firestix PC2-8500 I got 500fsb easily.
DSF
4,902
There's no fixed answer to this question. Sometimes it won't matter at all, and sometimes it will make a big difference. Is there a particular CPU you have in mind?
LOUISSSSS
8,771
58
you will need the higher ram speed if your motherboard's FSB goes past that ram speed. (assuming your ram cannot overclock)
for example
u have DDR2 800 ram (400mhz effective)
you have your e8400 overclocked to 400 x 9 = 3.6ghz and you want more
you try 450mhz and your pc freezes.
you are either FSB limited or ram speed limited in this case.
Jephph
333
Let's say the Q9300 (2.5GHz, 1333 FSB) So would that essentially be 333 effective FSB * 7.5 multiplier to get the 2.5GHz? So then with DDR2 800 RAM (400MHz effective) you could raise the FSB on the processor to 400 easily to get 400*7.5= 3.0GHz?
DSF
4,902
Yep, that's how it works. If you want to push that chip past 3 GHz you'll need faster RAM and a motherboard that can handle running the FSB that fast.
(On the other hand, some quality DDR2-800 modules will overclock well past DDR2-800.)
UpstartXT
209
Well I hear the best option to go with for gaming is the e8400, so that's the one I'm thinking about.
In reply to those talking about memory latency, I was referring to RAM capacity, as this is what I am changing as stated with the original post. If I have a stable overclock at 8 GB, will going down to 3GB mess me up?
