rbhawcroft
I have two signal busses, one is from a video source, and the other a usb source, so i cant control the timing of either, except that the video will always be on and pll locked, where as the usb wont necessarily always be on.
I need to synchronise the 4 bit 108Mhz USB based parallel bus with the 6 bit 108Mhz Video based parallel bus, before feeding them into a 10 bit wide serialiser for FO transmission.
Im not an engineer proper, so can someone please tell me exactly what components i need to impede the USB based bus so that it goes into synchronisation with the video bus? I have both busses on a accompanying 'rising edge clocked' 108Mhz clock signal.😕
