I just bought an EPoX 8K7A (best board I've ever used btw) and an Athlon 1.33
My idle temps with the case cover OFF are 52 C. Under full load I get 57 C. With the case cover on I was getting almost 63 C under full load..
My computer room has turned into and Easy Bake Oven.
I am using this case. (300 Watt toppower AMD Approved PS), a ThermalTake Volcano II HS and one case fan.
What should I do? Is this case just crappy for airflow or do I need an new HS?
Thanks,
Nate
Thanks,
Nate
