Dougmeister
Trying to wire two (2) LEDs (2.1v, 25 mA, 6.3mcd, Radio Shack #276-0022) to a single 3V button cell battery (CR2032). I know it's only 3V, but it worked fine putting the battery straight to the LEDs.
Tonight I tried putting maybe 6" to 8" of wire in-between and it works for a few times. Turn it off and back on, then off again, and the battery is "dead". Take the battery out, give it a break, try it again in a few minutes, same thing.
The wire I used was from a SATA cable I ripped apart. My limited electrical background is telling me that either:
1) the wire I chose had too high of a resistance,
2) I need to use 2 batteries,
3) I need to use some resistors, or
a combination of the above.
It has to be done by tomorrow night, so I appreciate any time you can give to this. I'll only have a few hours to work on it, so I'm hoping it's either a simple fix or else I go back to the "direct LED to the battery" trick.
Thanks for any help you can provide.
P.S. I'm using a mini toggle switch from Radio Shack, too. Not sure if that is important. It has 2 terminals. I wired one to the + of the battery holder (from Radio Shack as well), and one to the - terminal. Then the same to the LEDs (+ to +, - to -, and each of the leads from the LED are twisted together)...
4) Oh wait. Parallel vs series. Is that it?
