I have a couple of hw problems I need help on:
Consider baseband communications using a segment of coax cable or a segment of STP. Indicate TRUE or FALSE. "Manchester encoding will require twice as much bandwidth as NRZ-I."
a. TRUE
b. FALSE
Consider baseband communications using a segment of coax cable or a segment of STP. Indicate TRUE or FALSE. "Baud rate equals bit rate for NRZ-L and NRZ-I."
a. TRUE
b. FALSE
I got FALSE for the 2nd one and TRUE for the 1st one. Does that sound right?
a. TRUE
b. FALSE
a. TRUE
b. FALSE
