- Dec 29, 2010
- 3,034
- 1
- 81
Hello,
I have a 1280x1024 monitor. Is there a way to edit the EDID information so that windows (and eyefinity) think the monitor is 1280x800 (or a lower resolution @ 16:10 aspect)?
I think it's particularly difficult to trick eyefinity like this, because doesn't eyefinity look at the chip's information in the monitor for the EDID info, instead of reading a file that I could edit?
I would also like to do the same for my 1600x1200 monitor, to have the monitor identify itself as 1600x1000 for eyefinity purposes.
I have triple monitors; the two 4:3 monitors described above, and a 16:10 (1920x1200) as my main/middle display. Currently, eyefinity runs each display at 4:3 aspect ratio, using a lowered resolution for the 1600x1200 and 1920x1200. I don't mind the lower resolution, but I'd like to run all three monitors at a 16:10 aspect to avoid distorting the 16:10 middle monitor. If I edit the two side monitors to have 16:10 aspects, will that trick eyefinity into choosing a 16:10 aspect for each display (regardless of how low of the resolution is - I'll go as low as necessary so long as it's 16:10, or even 16:9 if that is necessary to get away from 4:3).
Thank you.
Thank you.
