Edit: Problem Solved. Original: Please Help!!! Problem with bit-torrent
ant80
411
I am using shaddow's experimental bit torrent utility. I read this article that said that I should forward ports 6881-6889 in order to increase the speed of the downloader. I am using a wireless G linksys router, and I forwarded the ports. The speed of download as well as upload increased by 300% and I was happy.
However, I am unable to start downloading new files. When I click on a file, the small file containing the file images is downloaded, but the download doesn't start. Instead, the bit torrent utility opens up and it says in red,
"ERROR (time of occurrence) -
problem getting response info - [Errno 2] No such file or directory: 'C:\\Documents and Settin' "
Ends there. Download doesn't start. Doesn't ask me to indicate the save location. I am kinda desperate here folks. Have a couple of 7 gig files that I almost downloaded completely.
I have tried to disable the port forwarding to no avail. Dont know what the problem is. Dont even know if the port forwarding is the problem. I would appreciate any help you guys can give me. Thanks in advance.
ant
Edit: Just checked the website again. It gives an explanation just for this. Sorry.
