Originally posted by: 4x4expy
The 9800np should not even be compared against the 9600p in this way. They have completely different GPU and arcitechture... It is not like the 9700/9500 family of cards that shared the same r300 GPU, with a change in clock speed and mem bandwidth. The new r350 GPU is ONLY in the 9800 cards. While the 9600p is a great budget card, by spending the extra cash on the 9800 you will be rewarded with better mileage out of your investment and it will return a descent price when you decide to sell it. I bet with all of the variations of the 9600 cards, in 2 years you won't get jack for a used one.
Originally posted by: modedepe
Pretty much all cards take a fairly large hit with aa or af on, some just take a larger hit. With a 9800 it's a much faster card than a 9600 pro, so even with aa/af enabled you still can get good frame rates. A 9700np would be fine if you can find one for about $200. It should be a good deal faster than a 9600 pro.
Are you sure the 9800 non-pro (325/290) is faster then the 9600 pro (400/300), since the clock speeds of the 9600 pro seem to be faster?! Doesn't that mean that when AA or AF are on, the 9800 pro will take a larger hit, despite the fact that he has more pipelines, and therefore the 9600pro would be better then?! Anybody can please explain this?! Thanks!!
Actually the 9600 does have the same GPU. The 9600 is just crippled as said before. It also doesn't have hyperz III+ only the III, And it only has 2.0 of the pixel shader or something else I can't remember right now while the 9800 has 2.1 of it and III+.
I'm not really sure of this. The manufacturing processes are different for the 9600 & 9800. The 9600 uses a .13 micron die while the 9800 uses a .15 die. While you can get some great OC numbers from the .13 core the 9800 is still a faster card. Anyway, I don't think that it's the case the 9600 is crippled, they were just designed to have less features that the 9800 from the beginning.
Is ATI stopping with making the 9800np's?! Where did you read that? I believe Hercules only does 9800 Pro and non-pro, I don't think they even do the SE version. Are you sure about this as these are all new cards I thought?!Next is that ATI has apparently stopped making 9800np?s and is now putting 9800se?s in it?s place. So IF you can find a 9800np and IF you feel that it is worth $150 more than a 9600Pro then go for it. Both support DX-9.
1/ What do you mean with that the 9800 need it's own power source? Don't both the 9800 and 9600 only use the PSU (with the 9800 probably requiring a bit more from it) or do you mean something else?Originally posted by: tallman45
Both architectures are vastly different, the 9600 is not crippled it was designed as a lower performing card. The 9800 needs it?s own power source, as is evident by the power connector on the card. The 9600 has no such requirement.
The 9600 also generates substantially less heat than the 9800, and has a much quieter cooling system.
1/ What do you mean with that the 9800 need it's own power source? Don't both the 9800 and 9600 only use the PSU (with the 9800 probably requiring a bit more from it)?Originally posted by: tallman45
2/ Where did you read that the 9600 pro has a much quieter cooling system then the 9800 non-pro. Does anybody know if Hercules uses a different cooler for there 9800 non-pro vs 9600 Pro card? I thought they used the same cooler on those cards, perhaps only a different heatsink design?! Anybody knows this for the Hercules cards?! Apart from that, how noisy (db?) is the Hercules 9800 non-pro, as I want a silent card as I also make music on my PC so I hope the Hercules 9800 np isn't too noisy and how does it compare to the Hercules 9600 pro??!
Thanks for the info!
Mike.
