Edit: Freesync does not work on Nvidia Cards, false alarm
alcoholbob
6,387
465
https://techreport.com/blog/34136/g...-begin-playing-nice-with-tr-freesync-monitors
If you have the 411.70 driver, or haven't downloaded yet, you should do so before it gets patched out and save it somewhere in storage, lmao! Seems like Freesync accidentally got enabled in this driver. It should be patched out soon, but for people who are bored, looks like it enables Freesync in windowed or borderless fullscreen mode. Has been tested with Maxwell, Pascal, and Turing cards so far.
Lordhumungus
1,207
33
Fingers crossed the community can drum up enough backlash for them to keep it enabled going forward, however unlikely that may be.
beginner99
5,318
1,763
This can go both ways. Either NV showing their greedy bastard colors by patching it out again or actually making it official.
DigDog
14,640
3,008
Patch it out?? Patch it out!? It's over,man. It's done. The internet is forever, once you release a whoopsy, it stayys forever. It never goes away.
Which leads to the question: accident or stunt?
Shmee
8,226
3,131
I hope it is because they have changed their stance? Time will tell.
BFG10K
22,709
3,003
No way they would give up their Gsync tax without a good reason. Unless this was intentional, it'll be patched out.
Just like how they disabled SLI on ULi chipsets, and how they disabled hardware PhysX with AMD cards.
Paying nVidia customers always seem to get shafted because of "certification" and "a better experience".
coercitiv
7,377
17,481
Update from Techreport:
After further research and the collection of more high-speed camera footage from our G-Sync displays, I believe the tear-free gameplay we're experiencing on our FreeSync displays in combination with GeForces is a consequence of Windows 10's Desktop Window Manager adding some form of Vsync to the proceedings when games are in borderless windowed mode, rather than any form of VESA Adapative-Sync being engaged with our GeForce cards. Pending a response from Nvidia as to just what we're experiencing, I'd warn against drawing any conclusions from our observations at this time and sincerely apologize for any misleading conclusions we've presented in our original article. The original piece continues below for posterity.
Reactions: ryan20fun
arandomguy
556
183
Shouldn't whether or not it is working be easily noticeable just by the eye-test?
That's what variable refresh rate has been marketed as regardless of brand.
DigDog
14,640
3,008
Im on 3xx drivers because ... reasons. Quake reasons.
Even if NV does patch it, i dont see a reason to not stick with 411 if you have a Fs monitor.
As always, i agree with BFG10K - NV has shafted people in the name of "experience" more times that i can remember; like not allowing me to uninstall SHIELD or streaming components from my GefExp.
But ... as long as they have the hardware they have ...
PeterScott
2,605
1,540
IIRC when people were using the hack to use Freesync by passing through a second low end AMD card in your system, someone tested it with a freesync monitor that reports current screen refresh in HZ. That is definitive.
DooKey
1,811
458
As always...vote with your wallet.
Reactions: kawi6rr and f2bnp
Avalon
7,571
178
I would find it odd that the functionality was there to begin with. Based on TechReport's update, seems they misspoke initially.
PeterScott
2,605
1,540
What's with that? I've no idea (asking out of genuine curiosity).
Freesync seems to add nothing, or close to nothing to the cost of a similar non VFR monitor.
Every Gsync Monitor requires a proprietary NVidia chip, and monitors with it cost at least $200 more, so NVidia gets a nice cut on every Gsync monitor. Hence the Gsync tax.
mikeymikec
21,005
16,256
Does AMD do anything similar? AFAIK their solution is called Freesync.
PeterScott
2,605
1,540
Why on earth would any monitor manufacturer go with nvidia's solution? Is it any better?
Because most gamers have NVidia cards, and if they want to sell them VFR monitors, only the proprietary NVidia solution will work.
alcoholbob
6,387
465
I guess what I dont understand is, even if this is not freesync, it seems to work similarly to freesync, or at least way better than vsync? Basically there's no tearing from 45-60 fps with vsync off in this mode, while clearly looking smoother than with vsync on. So whatever it is, it's basically some Windows desktop vsync mode that's way better than what's available in the Nvidia driver.
If I were to guess this is probably some form of triple buffering that Nvidia doesn't enable with their vsync in DirectX. I never understood why Nvidia only enabled triple buffering in Open GL, other than, I assume, to make vsync look worse and gsync look better in general gaming.
bystander36
5,154
132
In Windowed mode, Windows enables a form of V-sync and also enables a form of triple buffering. That last part is why the FPS will vary in such a way. The bad news is that it also causes more latency when you maintain your refresh rate. V-sync on a single GPU usually uses single buffering, so it will tend to lock at 30 FPS when it is failing to reach 60. With SLI or CF, it also behaves as triple buffering does, as there is an additional buffer added for each GPU.
This still doesn't vary the refresh times. When you are below your refresh rate, you'll get a mix of 1 or more frames of wait time between each change of frame. This causes some micro stuttering.
godihatework
So, now that the source has confirmed that this is not true don’t we think this thread title should be changed?
gdansk
4,589
7,722
It would be wise to update the title. Best to avoid confusion. We all wanted this to be true (except for some people who bought Gsync displays and don't want to feel like they wasted their money).
DooKey
1,811
458
Huh? I own G-Sync displays and have no problem at all if NV adopts VESA standards for VRR. It just needs to work as well as G-Sync does because I won't downgrade capability. G-Sync is a great technology. If HDMI 2.1 support of VRR is as good I'll buy a display with that as soon as I'm ready for more resolution above my current 3440x1440 UW.
gdansk
4,589
7,722
I said some, not all. I've seen a few of them.
